vferdman
Update.
I have replaced the bad 2SA684 transistor with KSA1220, but found more bad stuff. A 2SA641 PNP transistor is bad on one side. It is paired with 2SC945 NPN. I replaced it with a 733 PNP. Not sure if it will match up to the 945 properly. I also found a bad varistor on that board. There are two of them and one was open circuit. Fortunately I was able to find an old varistor from a 2270 restore (I think it's a different part, but I was able to get the biasing circuit to work in a stable manner and get it to adjust to 15mV as per manual). The other varistor was good, but the leads broke off flush with the package and I had to do surgery to open up the package enough to solder the leads back on and secure it with epoxy. Now I have a stable amp board, but the signal gets distorted somewhere along the line. I get very early clipping (compared to the good left channel) and the sine wave does not look right at anything but very low volume. I will now have to trace the singanal through and see what else is bad. So far I replaced emitter resistors, outputs, some of the intermediate transistors that were bad and all the electrolytic caps, of course.
This thing is really not cooperating and taking a lot of time to repair. Thanks again to all who help and support me. It is a learning experience for sure.
