the retro la
Hi Gang!
First time posting here, let me start by saying ahead of time that I respect and appreciate everyone's expertise here on AK.
I have a wonderful old Marantz 4240 that has served me well over the years. Recently a friend came over to listen to a mix of some recordings he recently made in a recording studio, which were a little heavy on the bass side of the frequency Spectrum. Not sure if that information is relevant or not, but I figured any info helps when trying to diagnose a problem. We had the audio source plugged into the Aux jack of the Marantz and all of a sudden after a relatively bass heavy portion of the song, the left channel became fuzzy and muffled sounding. Very similar sound to when the needle on a record player collects too much dust and dirt, and needs to be cleaned out. The volume was not abnormally loud.
Hooked up to the main speakers output, are Dynaco A25's. Hooked up to the remote speaker output are Optimus 7's. All speakers work fine, as tested by another receiver that I have.
The fuzzy output is on both the main and remote outputs. Issue seems to be isolated to the left channel, the right channel sounds just fine. It does not matter if the source is a.m. or FM radio, phono input, or auxiliary input.
I have filmed the issue, and uploaded it to YouTube. Here is a link illustrating the issue:
While I am by no means an electronics repair guy, I do have plenty of soldering experience, and have fixed guitar amps, and other electronics when I have been informed what the issue is, what to purchase and replace with. At minimum, with the help of the fine folks of AK, if we can at least isolate that it's a Transistor issue, and not a diode or capacitor issue for example, that will help significantly.
Thank you so much and I look forward to hearing from you!
