marantz 4240 pop
jFF_Bulbo
hello everyone.
I have a Marnatz 4240 under repair, the left amplifier failed and I was able to repair it, however a problem appeared that I had not noticed before working on it.
When the selector (S001) is placed on the FM input, when the speakers are activated, it emits a very loud noise, even the DBT lights up completely, and the FM is not heard.
In all the audio inputs, CD-4, phono, tape, a noise is heard, low in volume but always present, which does not depend on the volume at which the equipment is placed.
I have completely disassembled the front, checking cable by cable and I have not found anything suspicious.
I have disconnected J701 in both amplification circuits to connect my phone directly to these stages, and they work without the noise that I mentioned.
on power suply i changed C804, C805, R812, R811, H809 (diode) and the problem still hapening.
Has anyone gone through this problem?
thank you very much for your help
Were you able to solve this problem? I have the same issue. Thinking the power supply is not sending the correct voltage to the FM circuit, but am just beginning to troubleshoot and cae across this post.
Thanks
