Marantz 4270 - Digital source to quad sound
bencce
Hi All,
this is my firs post :) Recently we moved into a bigger flat and was able to change my audio system for a better one. I bought a 4270 with Pinoeer HPM-900 in the front and Grundig Hifi Box 500 in the rear. I've never dealt with the quadraphonic sound but started to read about it now that i have this amplifier. I really like Pink Floyd and thinking about listening to the DSOTM quad mix album from digital source from my computer. My problem is that i dont know how to do it, in the past couple of days i was researching but havent really found anything, already started to driving my wife crazy as i was dealing with this topic all the time:)
I understand that i need a 4 channel sound card, i can get an external one as my laptop does not have any. But how to connect it to my marantz? i have no SQA adapter so can i somehow play it in discrete mode?
thanks in advance:
Bence
Welcome to AudioKarma.
Is your Pink Floyd DSOTM quad mix a discrete four channel mix or is it a matrix mix? If it is discrete, you will need a 4-channel sound card.
Plug the sound card front channels outputs LEFT and RIGHT into the Marantz Front Inputs CD-4 AUX, LEFT and RIGHT.
Plug the sound card rear channels outputs LEFT and RIGHT into the Marantz Rear Input CD-4/AUX, LEFT and RIGHT.
Switch the Marantz front panel Selector switch to CD-4/AUX.
Switch the Marantz front panel Mode switch to Discrete.
Play the music: :music: :music: :music: :music:
Also, your unit might have a 2 channel/4 channel switch on the back. Believe that needs to be on 4 channel.
DO NOT CHANGE THAT SWITCH WITH THE UNIT POWERED ON.
Hi tcdriver, JJCalvillo,
after reading all the different quad formats it seems that i wanted to overcomplicate the last step as well, linking the DAC to the amplifier with the cables simply:)
I believe the Pink Floyd Immersion Box contains the original full discrete version of DSOTM.
thanks guys!
...I believe the Pink Floyd Immersion Box contains the original full discrete version of DSOTM.
Yes, the Blu-ray disc contains the 1973 quadraphonic mix as well as the 2003 5.1 mix. You will need a Blu-ray disc player with analog outputs or a HDMI to 5.1 channel converter. Using the setup menu in the Blu-ray player will allow you to play the 5.1 channel mix in 4.0 channels. Good listening.
