Ray122
Member
Alright, so I've got a Marantz 4270 with a bad channel, spitting out DC and throwing it into protection mode. Only one of the output transistors was shot, I believe it was the one that handles the negative swing. Otherwise, all the semiconductors on the board and otherwise are testing OK.
I can get the unit to come out of protection mode when I remove the output transistors on the bad channel, un-surprisingly, but with that, I can see I've got around 5.8V DC on pin J712 (the base of the output transistor). On the working channel, this is around .8V
(I should also note that I'm taking all my measurements while using a DBT so all the voltages are lower than normal.)
I can trace that 5.8V down to the emitter of the driver transistor (H712), through the base of H712 where it's now around 6V. Following that to what I'm guessing is the voltage divider that set the bias for the drivers (R723 and 725) at which point I have 7V. For comparison the working channel at that same point gives me .99V.
And this is where I'm stumped. Not really sure how exactly this circuit works here or if it's even a "voltage divider at all. Either way not at all sure why I'd have 7V on one side and .99V on the other if all of the components are testing OK. I did try replacing R723 and R725, as well as C710 but no luck. Would love some insight into what I may be missing here.
Thanks in advance!
Thanks in advance!
