I just swapped the Transistors on PM01 since I figured it could be the problem, no luck...
Yeah there's two boards, ones LF LR and ones RF RRshould be 2 boards looking at that one and also checking the manual .
there arent enough components on that board for 4 channels .
It's been preached and driven into our heads over the years to never switch the back panel switch while powered up saying it will destroy something internally.
I've never actually heard or read about the specific collateral damage that has occurred from doing so.
Bob
Yeah it is, the schematic has a typolooking at the schematic confused me as it must be marked wrongly .
ALRIGHT!
So some buffoon reversed the 2/4 switch in this unit, so I, like a fool, was trying to figure out my rear channels in 2 channel mode.
Now onto the actual problem... Rear left is very quiet, it's definitely in the preamp stage as it moves with the pre outs to the various main ins.
When I switch into 2ch mode on the front panel that channel gets very very crunchy. In discrete mode it's just quiet.
Maybe a bad diode or transistor in the preamp?
From the many 4270 and a 4300 I’ve been through, my experience is that the tone board is full of trouble maker transistors. I think every one I worked on had a problem in that damn board. I recommend taking it apart, it’s a bitch, recapping it, including the tantelums and replace every transistor while it’s apart because it’s a bitch to take apart. Did I mention, it’s a bitch.
The preamp board usually just likes new caps.
After that, any more weird issues are probably hiding in the DOLBY board.
Then a good power supply recap and may as well do the amps and you’re pretty good.
Once the tuner boards are recapped, she’ll be nice. The MPX board is a bitch. It’s under the AM board. Having the amp and power supply and AM board out or loose is the best way to get to it.
Get the inverter board and Phono board and you should be home free. Unless there are some tired transistors hiding out.
Piece of cake!
Enjoy.
It doesn't look thaaaaaaat bad.... The PU01 board in the 2325 was bad, this looks relatively standard aside from the angled board on the back end.
Obviously you’ve never done a quad.
Check back after doing one.
The angled board isn't that bad. Just take off the covers, pull the knobs, pull the faceplate, undo the nuts/washers on the tone control board, and the board comes out. Desolder the little vertical board, replace the stuff on it, call it a day. You'll need some bipolar caps but it's not wildly difficult. I did one the other day.
