hello there.
i have an updated on my project.
i have replaced all e-caps to include filter caps. i have cleaned all v-resistor and switches. new housing for dial lights and new led bulbs for dial plate. i kept regular bulbs for indicator lights. new v-resistor on power amp boards. once i put everything back together i went and i did the power amp alignment for 0 vdc and 12 mv. it went smooth. no problems. i fired it up to see where i am sound wise before i go with fm/am Dolby and all other adjustments.
Here is the issue.
i get sound at low level. both speakers same low level. it seemed to me at first that the power amp section is dead and the signal just passes without amplification. well i applied signal straight to power amps from different pre-amp and both channels work as they should, loud and strong. that take cars the power amp issue at this point.
well then i started messing with volume control and i noticed that it does not change the volume at all... if it does it is at very slight level.
bass, treble a and mid controls work as well. all filter push switches work but the loudness switch has no effect on the volume of the sound.
it makes me believe that for some reason the pre-amp is not amplifying the signal at all.
Before i started recapping and cleaning the volume control worked.
In addition i replaced the power switch as well. i got the e-switch
KutzlerTrans suggested. thx for that.
i removed the volume control and checked it for proper OHM reading and it seems to worked just fine.
That leaves me with the question, what is the problem.
Any ideas where is the problem?
i will upload some pics later with the progress.
