I picked up a 6100 TT recently and the anti-skate weight is missing. I'll have to make one up.
Does anyone know how to string the weight?
I got a copy of the manual but, it does not have a good picture, or describe well, how to string the weight.
Thx,
Rob
Thanks for the pic. It looks like the wire with the weight passes through the loop in the metal arm, from below, and then just rests against the rod with the rings cut in it. Is this correct or does the wire loop around that guide rod?
Feed the line back to front through the hole in the wire arm. Place the loop at the end of the line around the rod with the graduation rings on it. The weight will now hang freely from the arm.
The idea is that the arm must raise the weight as it moves toward the end of the record. The resistance of the weight is what creates the anti-skating force. The farther out on the rod the loop is the more the weight must be raised during playback so the greater the anti-skating effect. Each of the rings on the anti skate rod represents 1/2 gram of anti-skate force beginning at 1.5 grams.
Of course, this is all controlled by the weight. How much it weighs determines how much anti-skating force it can generate. Since you don't have yours you'll need to get or make one of the appropriate weight.
John
I am willing to send him the exact weight nd wire assembly, complete with the tonearm if he wants.
The OP does not need to figure out anything, as I have the entire assembly.
Al. Wise
Al. Wise
WOW!!!
:ntwrthy: :ntwrthy: :ntwrthy:
I'm going to amend my earlier post and go along with Earl on this. That really amounts to a serious score for the OP. The weight is one thing but that 45 adapter is what you use to set the stylus overhang. They're more or less unobtainium.
Now tell me it comes with the original headshell too!
John
