Marantz 6370Q - tonearm
Bluefisheye
Hi everyone,
I found this Marantz TT but it hasn't worked since several years. After the first trial, it works but there is some problem.
Firstly, the power supply needs a recapping.
Secondly, the cueing control doesn't work. As it is written in the service manual, I changed the rubber sleeve by a new one, for 094G and 048G parts. The grip is good and the contact is OK between the 2 parts. I added a few drops of castor oil as recommended by Marantz in the tonearm.
But when I push the button UP of the cueing, the piston goes up and goes down few seconds after. The tonearm doesn't stay up.
And the reject button doesn't work also, nothing happens when I push the button.
At the end of the vinyl, the tonearm stay on it and doesn't come back on its restarm.
Someone has an idea or an advise?
Thirdly, I cleaned the tonearm and I don't know why, I decided to remove the anti-skating knob for cleaning. And now, it's impossible to screw it at the right place. The button turns continuously without any change. I think, I have to dismounting completely the tonearm in order to put the button back in place correctly.
I never did it before, someone has a tutorial or something like this to help me or any advise?
Thanks a lot for your help and Merry Christmas ⛄
Merry Christmas to you too! I recommend posting this in the turntables forum, you're more likely to get a response. Good luck!
