Marantz 8B Resto
Crang
Well-Known Member
Acquired an 8B for restoration. Getting it dialed in and there are a few things off, so wanted to get input from the hive mind here. I had replaced everything I intended and finally tested it today.
- I set bias using DMM on Pin 5. Got all to -36. Then tested the meter and it read l slightly low on tubes A1 and B2 by the same amount and slightly high on A2 and B1 by the same amount. I did test R39 the 150R across the meter and it read 160R so in spec. Ideas? If I set bias with the meter all would be off.
- Gave it 117VAC and measured all voltages of all tubes. Everything within 3% except Pin 7 (grid) of both 6CG7s. Spec is +/- 10% of 90V and I got 80V and 83V so slightly more than the 10% out of spec. Anything to worry about?
-Had one tube red plated first time I fired it up after recap. It has been sitting for a year without use during recap. Moved the tube to see if it was socket or tube and it hasn't done it again. Run it 3 times for maybe 15 hours since and cant recreate it. Put some surgical tube over top of pots and filled it with contact cleaner working the pots hoping to get some down there. No idea if it helped. Socket tension seemed good and no DC leaks from the Goodall caps.
That's about it other than when I bench tested it I got exactly 35 watts from each channel. Was surprised- expected 37 WPC at least since they always underrate things although Im using some pretty old sacrificial tubes in there.
Work done- bypassed Selenium rectifier with diode and changed resistor R35 from 1K to 1.25k so bias pots stayed center range. All electrolytics replaced- restuffed the cans. Don't think Ill do that again! Rectifier diodes replaced with UF type. Replaced the .22uF bumblebees and 6.8R cathode resistors that had drifted a bit high. Set AC balance the service manual way, although if the meter is off maybe I screwed that up- one side was fine but one was off.
And yes I do all my work on the coffee table lol-
