HAL9000
i like marantz!!!
Hi everyone,
I have been working hard on a lot of marantz equipment The last weeks.
I had a SM7 ST7 of the esotec line, 4300 quad receiver and a 2500 for 300,-
I will post the SM7 and the rest later.
I got this Sm-7 amplifier from someone who hasn't used it in 20 years... you can imagine this most components are worn out. I switched it on, and everything was working very well. However on full power dummyload the Sm-7 started to oscillate Left more then right. problem was that one of the Big 80VDC 15.000µF caps was broken.
bad caps.
very bad solder points.
overview is still in good condition.
and it worked fine on low volume settings.
New power caps 100V 15.000µF eVox riFa
protect and VU amp.
all panasonic
I re-soldered the main amps and cleaned them, looks like new.!
cleaning is a good thing!
The Marantz sm-7 gave 2x250watts @ 8ohm load with almost 5.3A.
bad caps.
protect and VU amp.
all panasonic
