Marantz feet normal warp?
yamaha94
Hello! I have a Marantz 1030 I picked up recently and all of the amplifier feet are all angled the same way. Basically not perfectly flat. Just a wierd quirk I noticed. Are the Marantz feet on the comparable 22xx and 42xx models the same? This unit is in fantastic shape im thinking maybe the feet were replaced possibly with an aftermarket set that wasnt a perfect mold?
Ive attached a picture for reference of one side.
Thanks!
The feet are usually mounted to bent over "flaps" of the chassis so can be bent if the unit is dropped. Just unplug it, flip it over and pull off the bottom cover. Often some bending of the mounting point with a screwdriver to bring it back to square will cure that.
