bluehills5
My Marantz 2250b has a crackle or rustling sound when phono is selected. It kind of sounds like someone blowing across a microphone. I have tried 2 turntables and changed RCA cables. It is in both channels and goes up and down with volume and is quite noticeable even at 1/4 volume and it never used to exist. If you disconnect the tt but leave the RCA cables in, the sound goes away but it is independent of the tt being powered on or not.
Some time ago I recapped it including the P400 phono amp board but since it looks to not share any components between left & right, I can't see it being any failed component on the P400 board.
Ideas?
Ideas?
