EddNog
I just replaced this entire chain with a single device:
WiiM Ultra -> miniDSP Flex (digital output version w/DIRAC Live license) -> Topping E70 Velvet (feeding subwoofer) & RME ADI-2 DAC FS (feeding speakers) -> Topping B200 monobloc power amps
In short, the made in Japan Marantz M1 (for those who haven't heard of it yet) has:
AirPlay2 support
100watts/channel at 8ohms/125watts/channel at 4ohms
DIRAC Live (separate license purchase required)
Subwoofer LFE out with separate adjustable low-pass and high-pass filter options
Supports Qobuz Connect
Supports UPnP (I play my personal library to it from my laptop wirelessly using Audirvāna when I'm not streaming Qobuz)
eARC input (more on this below)
Dolby Digital+ decoding and downmixing (takes the LFE channel and blends it into the stereo channels so you get full frequency range with 2.0 or 2.1 setups and don’t miss any bass)
Other stuff that I don’t use (Tidal Connect, Spotify, Amazon Music, Deezer, Bluetooth, and other streaming services I can't list off the top of my head)
With regards to functionality pertinent to the eARC input, there are three additional movie watching features that work well and the WiiM lacks, which are Night mode (dynamic compression for low volume listening), a speech enhancement function with 5 different levels, and a non-gimmicky Virtual surround filter that simulates surround sound from a 2-channel system. The M1 significantly exceeds the WiiM’s performance for movie watching. This of course won’t matter to people who only use their WiiMs for music listening, which is understandable.
Many people have wanted WiiM to support third party/universal remotes like Sofabaton. Well the M1 does, as it has IR remote control learning. I use a One-for-All universal remote with my M1 which also controls my Apple TV 4K and my Sharp television.
All for under $1,000 (I paid $700US for a factory refurb unit with warranty).
Sounds just as good (in fact better when watching movies), and I’ve dramatically reduced clutter. All I’m waiting for is my new sub (Rythmik L12, which is on backorder for a couple more weeks or so). The amplification is a pure digital (PWM) class-D design that utilizes global feedback to ensure neutral response regardless of load (similar to the PFFB circuit for TPE3255-based amps, but this one has no analog stage at all, so NO DAC anywhere in the chain except for the LFE subwoofer output). Soundstage is stunningly deep and tall; image focus is laser sharp. Assuming there is technically more distortion than the Topping B200s, the M1 is sufficiently transparent enough that I cannot hear the difference, and my MoFi SourcePoint 8 speakers are high enough impedance & high enough sensitivity that the drive of the power amp stage in the M1 is more than sufficient to make them absolutely sing and hit reference levels with ease in my room (24' wide, 13' deep, 8' tall, with permanent openings to the kitchen and the hallway on the opposite end of the room)--I have to cap the maximum volume in the settings to 55%, based on the quietest track in my collection (Carmen After Bizet performed by All-Star Percussion Ensemble). There are two reconstruction filter options, and I am still flipping back and forth between Filter 1 (Marantz's proprietary filter) and Filter 2 (short delay sharp roll-off designed for maximum performance in synthetic measurement tests) having not decided which I like best, may end up depending on what I'm listening to.
Sometimes I play Apple Music losslessly to it via ARC from my Apple TV 4K, but my wife is enjoying the convenience of using AirPlay to listen to Apple Music when I’m not around or not using the system.
Of course, nothing is ever perfect. The HEOS app is not as advanced as WiiM's WiiM Home App, although it is intuitive and easy to use, which I cannot say for BluOS. Bass management of course is not nearly as good as with the miniDSP, but fortunately my new sub (Rythmik L12) doesn't have its own DSP (which introduces quite of bit of delay, around several ms on all of the SVS subs I previously owned), so I will be able to compensate for lack of delay or phase controls in the M1 by physically placing the new sub in a position that is equidistant from the main listening position as my speakers. In that scenario, DIRAC Live in the M1 works just as well as the DIRAC Live in the miniDSP that I removed from my chain. I do wish the M1 had 60Hz or 70Hz high-pass filter options for the mains (it has 60Hz for low-pass filter, but no 70Hz for low-pass either); it only has 40Hz or 80Hz for high-pass (and numerous much higher options which I personally deem useless). There is no parametric equalizer, but personally, I don't care, since it has DIRAC Live. It would have been nice if the unit included a remote of its own, but given that it has an IR receiver built in plus IR learning, I don't actually miss that much if at all in reality. Finally, for music listening, sometimes I like to enable ReplayGain, and the M1 doesn't support ReplayGain on its own--I get around this by using Audirvāna to stream my personal library or Qobuz over UPnP to the M1 when I want ReplayGain, which Audirvāna is able to apply before sending to the M1.
-Ed
AirPlay2 support
-Ed
