Btw, earlier I failed to measure the height of the original blue Elna main filter caps. 55mm. Which makes me guess that the ones in my '99 amp were probably 50mm.
Also before I did anything with this 5th amp I put it on the dim bulb tester, which it passed and then let it warm up directly on line current. Before doing that I realized that I had neglected to check and of these amps for DC offset.
Well, color me surprised. After warming up the amp settled in at 7mV idle current, right where is is supposed to be. But the surprise was DC offset.
I did not actually believe what I was reading at first. Tested it with 2 different meters, Fluke 77 and Fluke 79, on V and mV scales, and got the same reading. 1.4mV.
Not bad.
Cheers,
James
