Has anybody experienced meter/dial lamp dim/flicker on loud passages in Marantz receivers?
I re-capped all boards, except the tuner board, and replaced the original meter/dial lamps
with cool white LEDs on my Marantz 2226B.
At normal listening levels all seems fine. However, when I turn up the volume (50% level or higher)
the meter/dial LEDs as well as the DBT will slightly dim/grow brighter on loud bass heavy passages.
The DBT is normally off but will have a very small flicker/glow during the loud portions.
I tried the same test on my 2216B, not yet re-capped, and it does this too, just not as much as the 2226B.
Maybe this is due to the lower wattage amplifier in the 2216B, not sure.
I read another AK post where a comment was posted that said all of the smaller Marantz units, including
the respondent's 2240 do this same thing. Is there any remedy to help minimize this issue?
