Richs_Trains
Well-Known Member
As I posted before I have a 2220b with a nasty power amp board, the foils were mostly non-existent from the factory and all of the components were install with the pins bent against the PC board. I purchased a used power amp board for this unit because once I worked on the old board I could not get it to bias. Well the new/used board is just beautiful, all the foils are full and the components are straight in and trimmed right to the PC. My question, why so much difference in two boards from the same model, was there a time period when the manufacturing was below par, were all the 2220b's made in Japan? When I pull the board completely out of the unit, I will post a picture of them side by side. Also, I notice the outputs in the well made board say Marantz on them, the lousy board has the same #'s but no 'Marantz' stamped on it. Just curious .... Thanks for any insight. Rich
Here's the new/used board and it was a joy to work on with my new vacuum solder station, zip, zip, zip.
