Hi everyone!
I took a chance on an online auction in NZ for a Marantz PM 550DC Amp that was at a tipshop (like the recycling part of a rubbish dump) knowing that there probably was an issue. The unit's appearance is in great condition and I used Deoxit on the volume and balance knobs (the balance was a little crackly but this fixed it up beautifully).
The main issue is the sound output. At a low volume there is a distortion (I wanted to say crackle but it's not "crackly per say), then as I up the volume control the sound improves, it cleans up a bit but you can tell it just isn't quite right, then lifting the volume more the distortion cuts back through.
Things to note...
Here is a great site showing the "guts" of it https://insidehifi.blogspot.com/2017/04/marantz-pm-550dc.html
Any ideas before I buy 40+ capacitors would be much appreciated.
Cheers
Phil
Things to note...
- Using Marantz 8 ohm speakers
- Both left and right channels have the same distortion, left/right/together
- Can hear the same distortion using headphones
- Using the Phono selection
- Have tried an iPhone through the Aux channel with the same distortion
Cheers
Phil
