DaveScott999
I have a beautiful Marantz PMD-510 dual auto-reverse cassette deck. Occasionally it will warble horrifically on a cassette - in each case, the same cassette will play fine on my Nakamichi 500. Sometimes I can cycle the power and clear the problem. Other times, I can FF and REW and then Play - and the problem might be gone, might not: I think the power cycles and FF/REW are immaterial to some other random problem. The deck does it with BOTH cassette wells (each are auto-reverse wells) - either both play fine, or both have the problem. Initially, I thought the problem was the particular cassette - a clear-shell pre-recorded Dexter Gordon double-play in the first instance. Just now, it played a double Brubeck just fine, auto-reversing and sounding fantastic (and piano and alto require very accurate playback, as you know). When I popped in a Mingus just now, the warble and drag was horrific - yet the reels turn very freely. Any suggestions would be most welcome as to what the problem could be. I've re-gripped the belts, capstans, and pinch rollers.
