Marantz power switch replacement with new button
jmosher
I own a restored Marantz 2252 that I love. It's powered on nearly every day for hours on end. Recently the power switch was giving me some issues. I cleaned it, and that worked for awhile. However, the other day it died completely so I reached out to AK member DGWOJO for a replacement switch. Thank you Dave because that switch was here in 2 days flat!
I knew the replacement switch shaft was square (the original is a flat piece of metal) where the button would attach but I needed power and figured I would cross that bridge when I got the new switch installed.
Once installed the shaft on the switch is also shorter, so that presented another problem. I decided to go look in the garage and try and figure something out among my non-working electronics when I spotted this Marantz Model 5000 Cassette Deck staring at me from the shelves.
Bingo!
I pulled off a button and hurried inside to check the fit against the new power switch. Not only did it fit the square shaft, it was also a bit longer. (Marantz 2252 power switch on left, Model 5000 on right)
And here it is installed.
I hope this can help some else out there in AK land. Thanks again Dave for the speedy delivery of the new switch. I am listening to Casy Kasem Top 40 countdown this morning, drinking some coffee while writing this post.
Jeremy
Thank you Dingman. I hope it does help someone, that's why I created the post because this is where I come for help. :)
I do have exactly the same switch issue and possible solution. In my case silver button -bigger one , plastic inside is damaged so square shape is not there anymore.will try smaller and longer version to see how it will fit on 2215
Bingo!
Jeremy
Im looking for the marantz 2285 non b power swich button. Do you know which one is the correct one? The long or short? Which size precisely?
