preacherJohn
I have this Marantz 1060 that has this issue I've never seen, nor heard of before. When I shut it off, it still plays whether the selector is in Aux or a Tuner. It slowly gets quieter, and quieter until it stops completely. It reminds me of a capacitor discharging slowly. I didn't notice this when I first purchase this and checked it out, but, it was in such bad shape, and barely played at all. I've rebuilt and replaced the capacitors and the one transistor in the power supply. Then I moved on to the amps, recapped those, replaced a few out of spec resistors; the transistors all checked out. I also recapped and replaced the transistors in the phono stage. I checked the large filter cap, and the two coupling caps and they were good; within spec with low ESRs. The 1060 sounded so good, I left the preamp, and tone amp as it was. I replaced the remote speaker output backing plate that was busted, and also replaced the power switch that wouldn't stay engaged when pressing it over and over. I used the same .1uf snubber that came with the old pwr switch, but tested it, and it was within spec. The service manual called for 7.5mv DC on the power amp adjustment, and I set those. The amps were a little hot when first playing it back, but settled down to less than warm after adjusting the bias and the symmetrical clipping. When testing the power output, it was putting out 38 watts/channel before clipping. Pretty good using the old output transistors. I'm really impressed with the sound, and it has a good sine wave. Have any of you run into this problem before? I'm kinda stumped as to where to look. And the volume setting doesn't seem to make any difference as it shuts down slowly at moderate or very low volumes.
