Hello guys,
First tread and first recap
i would need some advise for choosing the right type of capacitors to recap Marantz SR4000. Ive read many post on this forum and learned a lot but still not sure what type of caps use as i dont understand enough the design of amplifier.
In all the posts i could find people using different versions of caps for power supply and signal path. This amplifier has power supply board together with main amp so im not sure if i should be using the same type of caps for the whole board or if there is also signal path involved?
I will do just this board for now, but i would like to order the caps for the whole unit and do it in the future. The main reason is that there is one leaking cap from the top and one of the main 10 000 uf filter caps is bulky on the top as well. They still read well but dont want to wait until they go bad completely. The DC offsets are 33mv and 50mv so i guess it ok as well but this amplifier is full of chips and i would like to risk loosing some if i leave it as it is .
I will be using Nichicon kgs for the main filter caps, Nichicon PW (or KL better?) for power board and ELNA Silmic II for the rest and Wima MKS2 for the little uf, if available. If you please could correct me where is needed.
I understand that it might be time consuming look at everything so if you could me some general advise ? Or perhaps mark for me the signal path in the pictures? Or should i use just all purpose Nichicon for everything and dont worry too much about it?
Can it be so generalize, that for all caps smaller than 4.7 i can use wima mks2?
Im writing all caps on all boards if its going to help and also uploading repair manual and schematics
P700 Main amp/ power supply (20x electrolytic capacitor)
CN 02 10uf 25v nichicons pw or kl???
CN 03 100uf 10v
CN 04 100uf 10v
C703 4,7uf 50v
C704 4,7uf 50v
C707 100uf 10v
C708 100uf 10v
C709 100uf 50v this one is leaky
C710 100uf 50v
C711 1uf 50v Nichicon pw or kl or wima or silmicII ??
C712 1uf 50v
C801 10000uf 50v nichicon LKG1J103MESCAK 10000uf 63v snap in (wrong value listed in service manual ) - this one i have bulky
C802 10000uf 50v nichicon LKG1J103MESCAK 10000uf 63v snap in
C807 470uf 50v
C808 22uf 50v
C809 10uf 50v
C811 470uf 16v
C812 10uf 35v
C813 10uf 35v
C814 10uf 25v
PE00 Tone Amp (10x electrolytic capacitor)
replacement
CE 01 0,22uf 50v nichicon UFG 0.22uF 50
CE 02 0,22uf 50v nichicon UFG 0.22uF 50
CE 05 4,7uf 35v silmic 4,7uF 35v or 50v
CE 06 4,7uf 35v silmic 4,7uF 35v or 50v
CE 09 10uf 25v silmic 10uF 50v
CE 10 10uf 25v silmic 10uF 50v
CE 17 1uf 50v silmic 1uF 50v
CE 18 1uf 50v silmic 1uF 50v
CE 23 3,3uf 50v nichicon UFG 3.3uF 50v
CE 24 3,3uf 50v nichicon UFG 3.3uF 50v
PH00 Low filter
CH 01 0,33uf 50v replacement wima mks2 0,33uF 250V ??
CH 02 0,33uf 50v
PK02 LED Power meter amp (7x electrolytic capacitor)
CK 01 10uf 25v
CK 02 10uf 25v
CK 03 10uf 25v replacement silmicII 10uf 50v or just all purpose is fine here?
CK 04 10uf 25v
CK 05 10uf 25v
CK 06 10uf 25v
CK 07 100uf 25v silmic 100uf 50v
PS00 switch circuit board
CS03 0,1uF 50V replacement wima mks2 0,1uF 63V
CS04 0,1uF 50V wima mks2 0,1uF 63V
P100 tuner / phono c.b. (33x electrolytic capacitor)
CA03 10uF 16v
CA04 10uf 25v
CA08 0.33uF 50v
CA09 3.3uF 50v
CA18 22uF 16v
CA20 22uf 16v
C103 0.33uF 50v
C206 2,2 50v
C209 1uf 50v
C216 0,47 50v
C217 10uf 25v
C304 3,3 50v
C305 2,2 50v
C306 0.22 50v
C308 47uF 16v
C311 10uF 25v
C312 10uF 16v
C313 10uF 25v
C314 10uf 25v
C315 0,47uF 50v
C316 0,47uF 50v
C319 1uF 50v
C320 1uF 50v
C321 1uF 50v
C327 47uF 16v
C401 3,3uF 50v
C402 3,3uF 50v
C405 100uF 10v
C406 100uF 10v
C413 1uF 50v
C414 10uF 35v
C415 1uF 50v
C416 1uf 50v
https://ulozto.net/tamhle/V9ofvY4LWvnO#!ZJMyAwR2ATEwBQD1LmIuAmpjZGNjLx9hqyqXLJECFaDkZzDmMN== service manual
Thank you very much to everybody who could help me here and apologies if anyone got angry
Danny
CN 03 100uf 10v
CN 04 100uf 10v
C703 4,7uf 50v
C704 4,7uf 50v
C707 100uf 10v
C708 100uf 10v
C710 100uf 50v
C712 1uf 50v
C807 470uf 50v
C808 22uf 50v
C809 10uf 50v
C811 470uf 16v
C812 10uf 35v
C813 10uf 35v
C814 10uf 25v
replacement
PH00 Low filter
CH 02 0,33uf 50v
CK 01 10uf 25v
CK 02 10uf 25v
CK 04 10uf 25v
CK 05 10uf 25v
CK 06 10uf 25v
CA03 10uF 16v
CA04 10uf 25v
CA08 0.33uF 50v
CA09 3.3uF 50v
CA18 22uF 16v
CA20 22uf 16v
C103 0.33uF 50v
C206 2,2 50v
C209 1uf 50v
C216 0,47 50v
C217 10uf 25v
C304 3,3 50v
C305 2,2 50v
C306 0.22 50v
C308 47uF 16v
C311 10uF 25v
C312 10uF 16v
C313 10uF 25v
C314 10uf 25v
C315 0,47uF 50v
C316 0,47uF 50v
C319 1uF 50v
C320 1uF 50v
C321 1uF 50v
C327 47uF 16v
C401 3,3uF 50v
C402 3,3uF 50v
C405 100uF 10v
C406 100uF 10v
C413 1uF 50v
C414 10uF 35v
C415 1uF 50v
C416 1uf 50v
Danny
