Marantz SR4000, One Channel Noisy When Using AUX
bzenic
Here is my issue:
Both channels working well on FM with earphones and/or speakers.
When I use AUX input things are different: one channel shows the typical "bad transistor" symptoms: crazy change in volume with distortion and noise.
I was thinking that the most likely culprit would be a transistor in AUX path, would it be tone control amp?
Any thoughts?
I don't think it is a bad transistor. Take a look at the schematic below.
All signal paths go through the same selector switch (AM, FM, Phono, Tape3/Aux) and the Aux input does not have the phono preamp circuit or the AM/FM front-end circuits, but goes directly into the selector switch. If the other inputs sound OK, then I would suspect dirty switch contacts. I would try to apply Deoxit to the switch to clean the contacts first.
The selector switch is mounted on the main board, and cable operated. They are known to get dirty and tough to clean.
Well, I sprayed CRC contact cleaning spray into the switch and it seems it's fixed the sound on previously noisy channel at least for now.
I'm very thankful to @dankik who saved me from torture of searching for and replacing the transistors.
