JCHaywire
Member
I'm working on a sweet goldface SR7000G. All inputs sound great. No problems--but the TUNING indicator is sitting on the leftmost red LED. Nothing moves it. SIGNAL STRENGTH is fully lit when indicating strong FM signals. FM output seems lower than other inputs, however, even when sitting dead on a solid local FM station.FM MUTING MODE only works in MONO, which is to say all signal is muted in STEREO mode. I'm using a relatively high-gain rooftop antenna, so that's probably not a factor. I don't have an FM signal generator, however. I've inspected connections, cleaned pots, tapped on and sprayed trimpots with DeOxit. Where should I be looking to bring this apparently attenuated FM signal up to snuff?
Any suggestions gladly considered. Thank you.
