MARANTZ switches help.
jFF_Bulbo
Recently i get a marantz 2270 which needs some parts. First, the dial pointer for the tuner, (i think it wouldn't be a problem), but my 2270 has a switch broken, the "mono r" is, i also have a 2250b for parts, so, i tried to remove the entire switch and then just solder it to the 2270. For my surprise, the switches in 2250b are larger than the ones in the 2270, unfortunately, i realized it until i had disassembled both units.
A friend of mine has a 2275 for parts, so, i would like to ask to the AK followers if anyone knows if the switches in 2275 and 2270 are compatibles.
If i understand this correctly, my answer would be to read the, "How to clean switches" sticky on the top of this page. You should not have to remove the whole switch, just the plastic guide.
nop. i want to know if the switches are compatible in 2270 using the 2275 switches. because i tried to use the 2250b but the switches are longer than the 2270 switches
Which switch do you need?
You can match the new to the old switch by how many pins they have. This ain't rocket science.
Tom
