Marantz Transistor/Diode/Trimmer Sub Guide
Hello All. I downloaded the substitution guide but I don't see a substitution for the 2SC496 (H714/H715). This transistor is used on the P700 power amp in the Marantz 2325. What substitution is currently being used?
Thank You
O. Frank
sometimes it's helpful to goto google and type in something like "2sc496" site:audiokarma.org when the built-in search function doesn't yield helpful results
Thank You
O. Frank
As per @catrafter the best sub is 2SC495. RF Parts used to carry it but they seem to be out. There are some on ebay that look legit from the pictures but as usual exercise caution.
Thank You
O. Frank
I just successfully used MJE243G at H714/H715 in a 2325
Well, I did another data dive and compiled a fairly comprehensive list of 99% of the transistors and diodes used in 70's era Marantz stereo integrated amps and receivers. I scanned threads until I was blue in the face, and scanned the internet for specs. I searched every Service Manual to pull a list of transistors and diodes. I looked for recommended subs throughout the threads, and collected the ones that were repeated often, or that someone had successfully used. I can't be sure of the appropriateness of any of the listed subs, but these are the ones I would start with if I were looking for a sub. I tried to search for availability, and only use subs I could find. Many recommendations that I came across turned out to be obsolete. I'm hoping the gurus will take a little time to scan for obvious problem suggestions, or to fill in blanks where I couldn't find any info. Please let me know if you find errors or have better suggestions for any sub. So, here is a link to the Excel spreadsheet on my Google Drive and I am attaching a PDF for those that don't have Excel handy. Give me suggestions on how to improve my list! Search for your transistor or diode in the left column (alpha order), and look for subs in the columns to the right.
Spreadsheet: Transistor, Diode and Trimmer Sub Guide
I used your list on my marantz 2215b and replaced a 2sc1384 with a ksc2690 and what a disaster it blew both of the power transistors on the heat sink. I put the 2sc1384 back in and replace the two transistors and it worked fine and the same thing happened to youtube channel auh-fix-it I don't think it is a good substitute
Were the pinouts the same?
Hey,
Working on a 2226B, and wish I had seen your transistor sub list earlier!
FWIW, here are the subs I've done so far:
Output drivers:
  • 2sc1509 to Ksc2690 (different from your list, the TO-126 worked fine for this)
  • 2sa777 to Ksa1220 (same as your list, TO-126)
For the outputs themselves, I wanted to stay with TO-220s since they were the closest physically to the old WM20 packages used on these.
  • 2sd587 to MJE15032 (your list has 15030, very similar)
  • 2sb617 to MJE15033 (your list has 2STA1694 in a TO-3, which would have been a tougher mounting challenge)
Both of the MJEs had the same pinouts and were pretty easy to mount in place of the old big-wing XM20s
So far, I have been pushing the receiver to check heat rise in the outputs, and it seems to be working fine and sounds great!
Scottie
Hi,
On the model 19 and 20.. what is the substitute of transistor 34-1034 ?
These older models don't work well for this list. I would suggest starting a new thread in the Marantz forum with a title like "Model 19/20 transistor sub?". That will give you more visibility and be more likely to attract someone with experience with those models.
Nice!
So many times I go searching for replacements for old transistors to find that many of the suggested replacements have been OOP for 20+ years. Probably because whomever is making the suggestion has been at this for 20+ years and still has a ton of the old parts!
Nice to see a list that you can go straight to Digikey or Mouser with.
Thank You. Tremendous effort.
