snorbans
Member
I acquired a Marantz 1060. An early one, but it sounded good, weakness in one channel, nothing major, I cleaned the controls, contact cleaner into the volume pot, worked it back and forth, left it to dry, came back, a track had lifted. I assume it was so oxidised that the cleaning weakened it to the point it lifted but I read that the cement can be weakened by deoxit, living proof that Deoxit trumps Servisol, not always in a good way, I don't see anyway round replacing it.
So I need to replace a Marantz 1060 volume pot which is a common part between models of the time - RM0254021. I will look for an original but if the part could be replaced, and the looks turn out OK, that might be a way to go (the actual part being an expensive option after postage from the US where they mainly show up).
RM0254021 | Variable | 250KOhm | A (with loudness taps)
Glad of any advice.
If I was to replace, the best option seems to be
Alps Blue 250K stepped attenuator - RH2701 - The shaft is 2cm and the shaft width 6mm - does this work Ok with the existing knob? I see some information here as to the wiring. Any tips?
Glad of any advice.
