Marantz WC Wood Cabinet Sizing
snowcatop
Can anyone provide me with the interior dimensions of the Marantz WC-10 and also WC-22. Looking to build a custom cabinet for my 140 amplifier. Does the amp just slide into these cases, or does it screw from the exterior? Thanks
I can speak for the WC-22 style. It is 5-1/8" tall and 17-1/16" wide at the front opening and 14-15/16 deep. There is no ledge at the back so your amp could hang out the back if need be. I hope someone else has the other cabinet!
P.S. The receivers (can't speak to any amps) need the feet removed then slide in from the front and attach through the case on the bottom, utilizing the threaded holes that are where the feet were. The cases came with 25mm long screws to reach further.
Also wanted to add: Welcome to AK!
