MrPoetry
I’m looking for advice on rolling the seven signal tubes in my McIntosh MC240. Budget is around $750, total (minus $200 already spent; see below). Two main questions: 1. Which of the seven signal tubes are worth splurging on? 2. What combination of tubes are likely to work well together?
I’ll set the key for question #2: I know I like vintage tube sound. I’ve already ordered a single 1950s Mullard longplate ($200) for the MC240’s V1 socket. My reasoning in spending more than a quarter of the budget on one tube is the relative importance of the V1 to the amp’s sonics (so I’ve been told).
So, about $550 still in the kitty. I have gotten the impression (largely from AI) that there are two other signal tube positions that add more character to the sound than other valves, but I’d like to find this out from experienced humans such as your august selves. If there are two other more important valves, I could blow more money on those (e.g. pair of Bugle Boys), and get less expensive, good value, solid performers for the other sockets. But is this sound reasoning (pun accepted)?. And then the next question is, what tubes to cast in those supporting roles?
The output tubes are already GE 6L6GC, which I think are doing a fine job. (If you can think of a reason to immediately replace these, do tell. But if you can agree that they’re good enough for now, let’s leave them for a later upgrade.)
My setup adds considerations. In signal path order:
To sum up, those questions once again are:
Let’s please agree that there might be better amps and speakers (for classical, anyway), but for now I’m only interested in enhancing the sonics of my heirloom McIntosh.
Looking forward to your thoughts!
- Amarra Luxe on a Mac, playing mostly classical, occasional jazz, less frequently rock (The Who’s Quadrophenia and Paul Simon’s Rhythm of the Saints already sound amazing; tube rolling is for enriching classical)
- Denafrips Pontus II (12th)
- Audio Note UK M3 (Mk II)
- McIntosh MC240 (originally my father’s):
- Recapped last week, testing at 47wpc, all other specs like stock
- Signal path upgraded in 1980s by Analogique (piggybacked polypropylene cans for better defined highs)
- Klipsch Heresy I + 2x Rythmik L12BO
- Which valves have the most impact on sound quality (i.e. how to allocate spending)?
- What signal tube combinations might work well as a set?
