Ok AudioWizard, take a handful of pictures to completely cover the insides.
Also, have you measured with a meter, or scope, set to AC the main filter +, and the tag board bias cap`s - terminals to see what the level of AC ripple is ?
And what does the amplifier draw from the 120 volt source at idle, IIRC it should idle around .8, or less, AC amps.
Also feel the chassis mounted can capacitor, and carefully feel the boards bias cap for unusually elevated temperature.
How well is the replaced chassis mounted cap`s ground tabs are well soldered to the riveted ground plane, and is that ground plane tightly riveted to the chassis ?
Do you know if the amplifier`s power transformer`s primary has been rewired for 120 volts from the original factory wired 115~117 volt tap ?
