Your experience is just beginning. If this equipment is new to you with little out of pocket, I would spend some time researching technicians in your area.
With them both working, a reasonably little amount of money will give you comfort that they are performing as they should. Many technicians will also touch base with you to confirm that the pieces they have worked on are set up correctly -- they will want you to enjoy the fruits of their labor.
You have great pieces, and they may well have been previously serviced. Someone with expensive taste might move to other equipment as these aged. By holding onto them, you have a level of confidence that they were well cared for.
