DrRobocop
Hello all,
I recently acquired a cosmetically very good condition MC2105. When I first attempted to turn the unit on nothing lit up, but the meters did a weak "bump" and then went back to resting. There was no function after that. I then proceeded to replace the filter caps (triple checked polarity) and the multicap can capacitor with the hamfest replacement. All the wiring looks good. I turned the unit on, the bulbs flickered then a fuse blew, I saw a small wisp of smoke and smell but could not locate it's source. There are no obviously burned or damaged parts after checking the unit. I then pulled the driver boards and attempted power on again, hoping the issue was isolated to them. Nope, another fuse blew. Now I'm not sure how to proceed. What would you recommend as the next step in troubleshooting?
Thanks for your help!
