paulram
Ever since I have had this amp the right channel seems to run warmer than the left. This I observed just placing my hand on top of the rear ventilated cover. Recently I did a recap and having the cover off I was able to touch the output heatsinks and confirmed that the right output channel outer heatsink ( with transistors Q124 , 120 .116 ) was indeed much warmer than the rest. In addition the heatsinked transistor on the driver board ( Q112) was also warmer than the other heatsinked driver board transistors. This is the transistor that also heats the diode , D104, beneath it. I swapped Driver boards and the situation followed the board. So now the left inboard output heatsink ( with Q123 , 119 ,115 ) got warmer than the rest. Is this transistor Q112 ( driver ??? ) going bad? If so what is the equivalent replacement? Any further thoughts?
