When you replaced the fuse lamps behind the meters did you have trouble opening the white covers? Even with TLC, I broke the locking mechanism on both meters on mine. I needed to make Velcro replacements. I have a complete LED lamp set from a fellow in Colorado.
Looks great! Wanna do mine? lol
If you live in Southern California, I'd be more than happy to help you out! If not, you can purchase all the LED's at Northridge Electronics Ebay Store except the socket LED's which will be available in approximately 45 days.
The bayonet lamps would need to lock into place (in the sockets) and the LED at a 90° angle would need to be positioned (or aimed) straight forward. Is this taken into account in the design? Yes the lamp housing has 'some' rotational adjustability. How are the LEDs arranged WRT to bayonet pins? and the sockets? What is the mechanical alignment procedure?
-Gregory
This MC2125 has been completely replaced with LED's. It requires 4 6.3VAC bayonnet LED's, 6 6.3VAC fuse LED's, 3 6VAC LED bipin LED's, and 4 12VAC bipin LED's. It also requires 4 resistor modification to make the bipin LED's work properly. Cheers!
Gregory:Will need eight socket (bayonet) type LEDs for the 2205 meters and probably some for the lower chassis. It'll be good to cool down the entire meter compartment of the amplifier with these. However I can no longer (or will no longer) be able to work z'bay so you will need to take a phone or email order. Hope there's no issue there.
-Gregory
