I was testing the filter caps on an MC2155 and found that they read between 18,000 and 19,000 uF. They should be 8,000 -10%, +75%, but that's more like +125%. The ESR is reading only around .04 ohms. I'm using a Peak Atlas ESR70 Gold for the measurements, which is rated for up to 90,000 uF.
Should I be concerned with these capacitance readings on these capacitors?
