I found the intermittent contact on my (new to me) MC2155. It was on one of the harnesses at the front of the amp. I tightened up the contact for that pin (on the harness) and it's 100% percent functional in both channels. Now....the bad news. There was a flickering LED in the rightward most housing (from the bottom) so I pulled it out and started to replace it. I had to go through about four LED's before I found one that was consistently "good". I move to insert the housing (the one with vertical holes) back into chassis and it must have (I had to take my bifocals off) brushed against something hot. There was a very small wisp of momentary smoke. Everything's peachy keen and all the Green LED's work just fine. I decide to peak around at the front of the amp before replacing the bottom cover and there's no meter lighting. The meters aren't deflecting. #$!$%.
I could use a little help. TIA.....
