funkenaround
on board type two I need the following
q408
q409
q410
q411
c415
r428
q414
q407
q408
q409
q410
q411
c415
r428
q414
q407
ok, so I`ve done a little research and please correct me if I have anything wrong
Q409---- 132-143 is an MPSA05(6)
Q410----132-150 is an MPSA55(6)
Q407----132-194 is an 2SA1360
Q414---- I cannot find a reference---the numbers on mine are 185/196/213
132-213 comes up as a completely different style of transistor the other two numbers don`t come up at all
will soon find out
pretty sure preliminary testing aside from the obvious exploded transistor that
the 132-208's are toast, a likely cause for the damage on the driver board?
well, not a great day, electronics store not much help
store #1 had 2 of the transistors(132-208/132/209--nte 60/61
headed to store #2, much bigger volume and they only had the small transistors on the 045863(132-143/MPS AO6 and 132-150/MPS A56
I picked those up and likely head back to store #1 for what they had
oddly, the NSD U07 would not cross reference in the NTE interchange, not listed
neither store had the 132 208/ MJ15003/NTE 60 or the 132 209/MJ15004/NTE61
it was 10000 degreees in the store taj mahal elecronics, my cellphone signal was next to 0, I gave up after 30 minutes of running from the front of the store to the back trying to research some alternatives
Not a great result
