MC2205 - Looking for a Preamp
mozcho
Well-Known Member
When I first bought my MC2205 I connect my source directly into it without a preamp, using the volume knob on the MC2205 for control. Later I acquired a vintage Marantz 1060 so that I can hook up my turntable, PC (playing digital high-res material) and CD player into it and use it as a preamp to feed my MC2205. This combo works fine. I am just curious if getting a dedicated preamp would improve sound significantly or not?
In my place (Malaysia) Macs are expensive and not as abundantly available as in the US. I am trying to keep my system as budget-friendly as possible. Currently these are on sale (prices have been converted to USD):
C34V & MC7200 - $2340
C39 - $1030
C40 - $1550
MX118 - $765
MC7106 (THX) - $1340
MX110Z (Tube Preamp with Tuner) - $1980
I will play more and more vinyl records and high-res tracks (DSD etc.) in future, CDs will be less and less. Any advice?
I'd check out the MX118 if it includes the remote since you want to keep it budget friendly, but it doesn't have a phono input, so you'd need an external phono stage (can buy one that'll do the job for less than $200). While you're carrying along some extra circuitry you'll never use, it should give you a taste of the Mac sound without investing a lot more into pricier models.
Plus, it has a tuner if you're into that, variable loudness, etc.
Yeah quite tempting...
Depending on your speakers you might find that 7200 to be a totally different experience. Especially if the impedance dips below 4 ohms. The 7200 becomes a real plower house in that case capable of twice the peak power with lower distortion and more signal to noise than a 2205. Plus some say the 7200 Power Guard is more advanced and less noticeable. Without autoformers the 7200 has a much higher damping factor and with big speaker wire if you feel your woofers are a little fuzzy or two warm a 7200 will clean them up instantly. Not as much as a Crown amp, but then I found Crown and other direct coupled amps to be to dry. That I can't say I have heard, but I suppose depending on the speaker that might be true. I have a C-34 that Audio classics recently fixed for me and it performs very well. If you are into recording the flexibility of the C-34 is fantastic. C-40 is the next step up in performance, but neither have a MC input. Bummer. I bought a MP 100 to solve that issue. I like the digital out put to feed the HT system too.
Nothing at all unless it's a phono.
The biggest downside IMO is that you have no unified volume control, if your source doesn't have volume control you will be constantly re-balancing your volume every time you turn it up or down.
What is your source?
Thanks! A homemade phono tube preamp is the source. It worked fine when I gave it a try, but I should stop, you are saying?
No, you're fine. Your source to the amplifier is a phono preamp. If the phono was fed directly into the amp it wouldn't work, that's all I was saying.
Thanks. New to the MC2205 and McIntosh in general, thoughI've been admiring for years.
My current siutation totally works for me, and I LOVE the sound straight from my tubes. Still trying to figure out which Csomething to try out. I love the dual phono inputs of the C32. I'm a MM guy, but will get to MC someday, probably. I like the idea of using 2 Fluance RT85s (i.e. two turntables).
Is there anything wrong with connecting the source directly into the 2205?
I have a 2205 and tried plugging the MB50 directly to it. It sound worse than with the C34v between them. With this preamp, I get a “warmer”/“full body” sound.
