Alfmonster
Hello AK!
I’ve recently changed my speaker wiring setup to go from the mc225 amp to the c27 preamp so I could use the headphone output.
I’m reaching out to the AK community to see if maybe someone has experience with biwiring to the speakers directly from the preamp — and perhaps would be kind enough to share some advice to help.
Also, when wiring directly from the amp to the preamp - do you use the ohm that your speaker needs or do you go higher? (My speakers require 8ohms).
Thanks so much I’m advance!!
Edit: gear — thanks @Pio1980
