Hello I am a new member and I’ve been very grateful to the many posts all of you have on here that have helped me over the years.
I have a MC 240, two of them actually, both bridged mono. One of them has hum, but only when the selector switch is in mono. Becomes less in twin mode and still less in stereo mode. Touching the chassis reduces it as well. When turned down it’s silent. The pot seems to be scratchy, but it’s an Alps pot and when taken apart looks and measures perfect. It dramatically changes volume near the end of the taper.
This is all in the context of a recap with Russian PIO K40y-9 caps. They were replacing some Jensen caps I put in 20 years ago some of which were leaking. None of these Russian caps showed leakage. No resistors are out of spec. I also cleaned the stereo-twin-mono switch.
Thanks in advance. Any help would be appreciated
regards,
Karl
regards,
Karl
