MC2500/MC2300 Advice
They're racked up already. Sitting here idle. One came stock with the thermostatically controlled fans, the other I modded with that feature (1Y amp - fans ran continuously). One amp is dead quiet, the other has the occasional transient from the fans turning OFF and I can't remember which is which. I meant to look at that more closely about 8 years ago . . . so, it's still on my "list" if you will but I think for the foreseeable future it may be used as is.
I decided to give another listen to the MC2500 driving the XRT20's off the 8 ohm tap and driving the XR19 speakers with the PC2602 Yamaha pro amp for my Mcintosh XRT39 stack . I was literally blown over. I have drove both pair off one amp mcintosh and yamaha at 4 ohm load combined. The sound stage literally doubled this time. It feels like infinity.
Difference the Yamahas fan never initiated. The MC2500 fan will kick. However botb are running cooler than when driving both pair. The Mcintosh picked up lots of highs and mids. Also driving the woofers with more control. Sharper bass. The Mcintosh is kicking harder set for 0.75V gain gain where the yanaha is a 1.25 volt input. Should I balanace them or let the XRT20 take more wattsV. The PG kicks way before the yamaha clip light.
I read the owners manual on the .MC2500. The voltage is way higherat 8 ohms. The current is equivalent accross ohms. Why the surpise fidelity increase?
Hmmm ... Well, you definitely need to balance the output of both pairs of speakers with an SPL meter and pink noise. You have increased power by approx 50% so a volume increase would be expected. Like I said in another post, it's really about achieving the ideal match between the amplifier and speakers.
Now, quit horsing around and find another MC2500 ...
Damacman
Thanks for the input. Now I have a reason to source a budget conscious SPL meter. I wonder if there is an iPhone app for SPL? I am a bit weary of iphone having any microphone range 20Hz to 20KHz.
The thing I never tried is running both 8 ohm speakers off the MC2500s eight ohm tap. I thought autoformers gave 500 true watts no matter the impedance? It is better sounding more detailed, mids, highs and sharper bass the two amp hook up so far. Ear in front of speakers I can't tell dB difference in levels though amps have some watt differences. Trying to match gain by guessing and dialing back MC2500 made SQ worse than full gain. It may just be louder sounds better.
I am on the fence if I should pick up a McIntosh preamp or another MC2500 next. The pre in the Yamaha R2000 is very detailed and a great phono section. I have been eyeing and bidding on McIntosh preamps no joy yet and let a black face MC2500 go since mine is silver. I have been considering trying a run just off the Emotiva stealth Pro DAC as a pre with balanced cables to the PC2602 and unbalanced to MC2500. The feeding phono off R2000 record out. It is a Opamp driven preamp versus discrete components like the Yamaha. Plus still use Yamaha receiver amp to drive my pool outside speakers and sub.
Decisions on spending stereo dollar always a quandry.
I am all ears for opinions.
Damacman
iPhone audio measurement apps are fine, the microphone in calibrated in the app.
I have the Studio six digital apps.....they actually pretty accurate. Use the "pro" ones.
You can get the studio six package with RTA SPL meter, oscillator and a bunch of other stuff.
It costs a couple of $ but its worth it, there are a lot of really crap apps out there, usually the free ones are not that good.
Autoformers will have the amp produce the same power from any of the taps as long as they match the speaker impedance.
When you start running 8Ω speakers off the 4Ω tap, then the amp will produce less power, or conversely if you run 4Ω speakers off the 8Ω tap then the amp will produce more power, which may or may not not be a good thing.....
I don't know what you're after in a pre-amp, but I like the newer ones, I have a C48 which I like, I can't see myself replacing it for a long time....
Its a nice package....as long as you are using JRiver 20 and have it set up correctly, the DAC is very solid, and sounds really nice.....
Autoformers will have the amp produce the same. power from any of the taps as long as they match the speaker impedance.
Kevzep,
Thanks for the heads up on SPL apps. I'll take your advice.
As for the autoformers the two 8 Ohm speakers in parallel equaled 4 Ohms.
The MC2500 owners manual indicates at 4 Ohms amp load volts is 44.7 where at 8 Ohms load volts are 63.2.
If the amp puts out the rated current of roughly 50.3 amps on the top block diagram then:
V=I x R
402.4 Volts = 8 Ohms x 50.3 amps
201.2 Volts = 4 Ohms x 50.3 amps
So in theory the XRT20 speaker is being driven by double the volts.
I did notice when running both speakers on MC2500 the amber max power lights on speakers had no problem lighting solid and blowing 3 Amp fuse on XR19 rated for 2501 continuous. The XRT20 rated at 3001 coninuous seems to light its max power sooner when riding 8 ohm tap by itself with its higher 4 amp fuse. Will still take all the amp has to give. So I think in thend watts are watts. Speakers are just driving easier at 8 ohms with more potential voltage ready to go. It just sounds quicker and more detailed its hard to explain without hearing it.
Maybe that's reason Damacman loves his MC2600 which has a power supply that can double MC2500 current.
Anyone else experience what I am?
As kev states, the iPod apps are pretty decent for SPL measurements like this.
One AKer here (Don Bocadelli) had a few silver/black faced MC2500s ...
