The pre is C11 after full restoration.
The speakers are JBL 250ti.
The sound is less detailed, cloudy.
I'm considering to replace all the tubes (4 KT88 + all the small tubes) on the new MC275 with the Genalex reissue tubes.
This might improve the sound to be the same as my old MC240.
Am I right ?
What tubes are in the 275 now and how much listening time do you have on them?Hello all,
I have a new MC275 MK-VI but I'm not happy with the sound.
My old vintage MC240 sounds much better then the new MC275.
I wonder, if I will replace the new MC275 with a vintage MC275 (after full restoration), will I get a better sound ?
Regards /Ofer
OK, but in general, which amp should have a better sound - the old 275 or the reissue 275 ?
Why is that ?The only thing that can be said with certainty is that the older version is definitely better suited for use with the C11 than the VI.
Why is that ?
My other option is to sell the VI & to buy original 275 instead.The input impedance of the original version MC275 250K ohm.. Being that of the VI is 47,000 ohm which is below expressed McIntosh's instructions that the C11 be operated into 50,000 ohm or greater, would strongly suggest the original version MC275 is better suited with that model preamplifier.
For the op, with what preamp?First: You say new... How many hours do you have on it?
Then: 275 = KT88 and 240 = 6l6. It may just be that you like the sound of the 6l6 more.
Many years ago I had a 240 in house for a short while. I liked it a lot more than the 275's I had/have owned (never an original one though). Last fall I got the new 275 VI and think it's the best by more than a little. It did take some hours, but it's a keeper.
What's 'best' (version or amp) is up to your ears to decide and also what speakers you use.
So, a "better suited" means a "better sound" ?The input impedance of the original version MC275 250K ohm.. Being that of the VI is 47,000 ohm which is below expressed McIntosh's instructions that the C11 be operated into 50,000 ohm or greater, would strongly suggest the original version MC275 is better suited with that model preamplifier.
