MC275 or MC2102 or MC2000???
robbanks
The idea of trying a Mcintosh tube amp has been eating at me and I'm thinking of checking out something used.
Anyone have an opinion of either dual MC275's or MC2102's or one MC2000, based on first hand listening?
The price difference between these options isn't that huge that I would rule out any of the options if one offered significant advantages.
Of course the MC275 and MC2102 let me go halfway down the road I'm considering, before using each in a mono configuration. Feedback I've read from other people usually seems to suggest a performance upgrade when using 2 of either of these amps.
I'm currently using the solid state stereo MC602, and like it, but at some point, I want to get the tube idea either in or out of my system!
Thanks,
Christian
Have listened extensively (owned) to the MC275MkV and MC2012 (also the new MC75s, never heard an MC2000). The MC275MkV is a terrific tube amp. Would still have McIntosh tubes if I had not "up-graded" my speakers (from 93db to 87db). My experience is that the MC275 is a much better sounding amp then is the MC2102. Thinking I was upgrading, I traded my MC275 for an MC2102. To my ears was a big sonic come-down. Fortunately, I was dealing with Frank Gow at Audio Classics and he allowed me to send it back after a couple of months of trying and get my MC275 back. Was only out the shipping costs. Even tried a pair of MC275s in mono. To my ears, the single pair of tubes per channel running in PP stereo sounded better than running them as monoblocs. If you go from an MC602 to tubes, you will likely find a big change at the bottom end of things. Obviously, YMMV.
All great choices... just which one to pick:scratch2: An MC275 is rated for 75wpc, typically peaks at 92wpc. Put those in a mono setup & you will have over 180wpc. Pretty darned substantial! But you won't have meters.
The MC2102 is rated at 100wpc, does about 110wpc, mono will give you over 200wpc.
The MC2000 is 130 wpc and is a dual mono design, is a limited edition unit, has the meters and looks amazing.
Myself, I have an MC275 & love it. It delivers everything I need, and also gives me that classic McIntosh look.
What speakers are you running? Maybe that would be the approach to help narrow the choices down a bit.
Great info! Thanks! Two things surprise me, somewhat, though. You're saying you like the sound of one MC275 vs two in a mono configuration? Do you attribute that to parallel mono as a less favorable way to operate an amp? Based on reviews, I'd guess the MC275 is a richer sounding amp than the MC2102. Is that your experience?
I like floor standing speakers. I'm using smaller floor standers right now, with 89db sensitivity, but they don't have much in the way of lower frequency weight in my rather sterile sounding room. So I'm also considering a swap of speakers with a bit more heft in the bottom end. Chances are the choices would be of similar sensitivity.
I say keep your mc602 and your current speakers. Add a second system with the mc275 and a set of 100db+ speakers.
I pondered this question when I was looking at buying a modern McIntosh tube amp. For me it boiled down bang for the buck. The Mc275 IV is a bargain compared to the cost of the MC2102 or the MC2000. Granted the latter amps have more power, but the MC275IV while rated a 75 wpc I have read reviews that state the full power output at 90 to 100 wpc. Your looking at 120 wpc true output for the 2102, but it uses twice as many expensive KT88 power tubes and has the same power transformer as the 275 IV feeding them.
The MC2000 is a beautiful collectors amp that commands a very high price. The MC2102 is a fine amp. I have read that many folks prefer the sound of the Mc275 IV/V overall. I don't know how McIntosh did it, but they have preserved the original sound of the MC275 in their newer releases. There is a reason why the MC275 is nicknamed the "vampire amp" it refuses to die.
Richer sounding, better extension both at the top and bottom. More detail. To my ears, just better overall sound. Instantly recognizable difference between the two for me. My understanding is the power supply/transformer in the MC2012 is not substantially larger than the MC275, so is taxed by the additional load. It has been my experience that the best sound in PP/Class AB amps is when one only has a single pair of output devices per channel. The MC275 has only two tubes in stereo vs. four when used in mono. The only proof I have of this is my ears. But the single amp in stereo was better in the mids, where most music resides, especially voices. Try one first for several weeks. Then try a pair in mono and see what you think. I had the one MC275 for at least a year before trying two. Simply sold the second one after a couple of months as the one amp was better with my Wilson speakers. Again, YMMV. And, unless you are truly into 'head-banging' music listening, any speaker of 91db+ in an average size room will likely be fine with a single MC275.
wgrr and MX117.MC7150,
Both of you make very strong cases of where to start... and quite possibly where to end up. And coincidentally, it happens to be about the least expensive way to test the Mcintosh tube waters.
Thanks for your input!
I managed to score a couple of Verdin Mac monoblocs on Fleabay. They have the MC75 power transformer and a special quadrifilar OPT. 16 Ohms only and runs 4x 8417's with the older Mc30 style front end. Rewired the output stage and power supply to be more like the MC75; slid in 6550's (4x a side) and they rawlk. Now they easily exceed 130 watts into 8 Ohms and the best thing is that I am into them way under 2 G's with a set of 8 NOS GE 6550s.
You see those church bell amps often. You'd likely make many friends here if you began a thread and outlined the specifics of the conversion.
Nice. Can you post a few pic's for us? Thanks.
If you want big Power Audio Classics has some MC3500's which will wipe 275's off the map rated at 350 watts putting out 400+. The distortion is as low as a 275 MK VI, with the 275 having a touch better signal to noise. The 3500's have better high frequency reproduction has been my experience. Or you could look for a pair of 2301's.
But I would never give up your 602. Remember changing speakers will give a magnitude of change compared to changing amps. And as others have said speakers you want to match with the 275 should have a minimum of 95 db sensitivity if you want to produce concert level. Tannoy, Altec, JBL, Klipsch, come to mind. I had 275's way back when and will agree mono operation is nothing special. The best sound I got was bi-amping using an external electronic crossover.
I've had the pleasure of owning a pair of MC2012's and an MC275V. I still own the MC275 and prefer it over a single MC2102.
If you are positioned to get a pair of MC2102's, and have 4 ohm or greater speakers, you can run the MC2102 in mono bridged mode and the transformation is magical. They sound very similar to the MC2301 flagships I am running today.
If you run MC2102's or MC275's in mono parallel, you get more of the same sound you have with a single amp running stereo.
Hope this helps,
Tom
MY speakers don't like tube amps with low damping factor, and that includes the 2000 series SS amps and most later SS amps with Autoformers. But when auditioning new. speakers using Mac amps I find the 275 to be just a tad warmer from about 280 hz down Depending on the design of the speaker and crossover there is no difference in the bass. Its the fact the internal impedance of the 275 and other tube amps reacts with the reactive components of the speaker more readily than the SS state units with a 3 to 6 times higher damping factor. I was listening to Magico speakers with 601's and they were just too dry. Changing to a 275 helped warmed things up. They sounded the best with 2301's. It wasn't a power issue, as we were using around 12 watts at most listing at about 10 ft/ I ve heard 275's from old driving every thing built in the 60's and early 70's from Klipsch horns to AR-3s and 3A's. KlH 9's and Paragons. . and almost everything Altec and JBL ever made, and including Bozaks. They are a great amp , but if I had my Choice I'd have a 7100 or 7200 direct coupled amp. They are much more accurate in the low frequencies, can drive loads down to 1 ohm, so speakers where the impedance wanders all over the place are handled superbly, where all the tube amps will have heart attacks. Appogee, Acoustat, some other panel speakers come to mind.
Loved the note about Frank. He was a great guy. He sent me my first Dynavector un-announced to try. I had been bitching about my Stantons and Ortofons. Telling him I wanted smoothing smooth like my Sl 20 Mk II that could track like my 981HZ or V-15 V and sounded descent. Next thing I know I had a new HO Dynavector. They are so good I have started recollecting LP's and enjoying a new old world of sound. He helped recondition Mac pieces I wanted to keep and up grade the rest. I miss that man even today. I ended up paying for more than one Dynavector.
Hmmm . . . well, I've never owned a pair of speakers that one of my Mc amps couldn't drive well and make sing. Even the MC225, MC240, MC60s - those sounded just great with everything I connected to them. I only owned an (original) MC275 for 6 months or so - but again, never had a problem with it in this regards either.
Personally, I think you've got a better chance of achieving that synergy we all look for with a McIntosh amplifier than with other brands. I've owned numerous other brands of amplifiers and most of them were very sensitive to speakers used with them. I guess that's why I don't own any of those amps any longer.
As I remember the MC 2000 is a hybrid amp with a SS buffer in the circuit design. Some reviewers thought the amp was a little colored because of that. I never heard any issues. If you want a real tube sound with low distortion you have 2 choices. For best signal to noise, the MC 2301. For the lowest distortion and most power with that true warmth The MC3500. Maybe Steve at Audio Classics will give you a New Years surprise with the price. But that said I would start out with the newest 275 I could afford. Unless I was fortunate to be able to afford 2301's for inefficient speakers.
