briandrex
I'm trying to drive the bass towers of Infinity RS1B speakers with an MC352 amplifer. On the back of the SERVO there is a switch for non-inverted and inverted. The ADCOM GFA-355 I was using was fine on non-inverting, when I hook the MC352 up with pre-amp (C2300) volume on zero it just makes a clicking sound about every three seconds, not a thump or anything bad just a click like a relay switch going on and off.
I hooked the ADCOM back up and everything works fine so I'm positive it's not a bad connection. I don't want to change it to inverted as I know if this is set wrong I could damage the speakers or the amplifier. I've searched the internet and can't find an answer for this. I did read somewhere where McIntosh said most of there amplifiers especially all the newer ones are non-inverting. It this is indeed the case does anyone have a reason why this is happening with the MC352. The amplifier works fine in a traditional setup with other speakers. I double checked to make sure it wasn't something wrong with the amp.
