garmadon
I recently bought a pair of MC60. The seller said they were re-cap and checked in specs. However, when connected to my 92dB speakers, there's noticeable humming from 8 feet away. Power tubes are new Tung-Sol.
I search in the forum and I have been tried the suggestions I found:
1 - Adjust hum pots: hum doesn't change much
2 - The Gain knobs:
- when at 0 (all the way counter-clockwise) no hum, but also no sound from speakers
- Hum increasing when increase the gain, at 9 o'clock the hum is acceptable but I still can hear the hum at 4 feet away
3 - Un-plug the input: Hum still there
4 - flipping the plugs over: it doesn't help
5 - unplug the V1 12ax7 tube: the hum goes away, no hum at all
Any thoughts on what would cause this? Is it normal?
Both amps look identical inside, so they behave the same way with all the tests I tried.
2 - The Gain knobs:
