McIntosh 1900 Receiver Noisy on startup
cableguy2
Well-Known Member
So I have had this receiver for a long time, serial number 9x256 and it just started being noisy through the speakers on startup. Then it goes away and it sounds normal until you turn it off again. So I guess my question is this a power supply problem or possibly a cap problem? Downloaded a service manual for it, hope I got the right one for the serial number, as there are a few of them. Or is it something else I should be aware of.
They are darn heavy so getting it downstairs to a workbench is not going to be fun, so I was hoping somebody could point me in the right direction, because I know that some of it is card based and I would much better take something out if I can get away with that. Doing a search didn’t seem to find me anything, but maybe I wrote it wrong. Took it out of service for now, hope you folks might have had this issue and can point me in the right direction. Being almost 75, arthritic, etc, any help would be appreciated.
Gary
If getting a crackling noise through the speakers that eventually begins to clear up, it's usually an indication that one or more capacitors are beginning to fail. Best bet is to ship it out to Audio Classics.
Yeah, thanks for that response. I had a chance awhile back to trade it and I could have got $730 for it, but would have needed to purchase something much more expensive. The damn thing is heavy to move around too. Just got done doing a Bill D upgrade on a Carver C-1 preamp. It never seems to stop.
I would try cleaning the switch first. Sometimes the sound is an arcing from carbon on the switch.
MAC1900 is 33 lbs which puts in the lightweight category as far as Mc. At 40 lbs, the MAC1500 is deceiving for its size but to be expected due to its tube amp section.
Hmm, I replaced the volume switch a few years back, when you could still get them. I could try that, it’s on the bottom if I recall that right.
"...it just started being noisy through the speakers on startup. Then it goes away and it sounds normal until you turn it off again."
Your description ^^^ doesn't sound symptomatic of a worn/dirty VC. It sounds more like classic cap failure.
Not always. I had similar issues with my C36. Working the volume control solved the problem.
Crackling sound or a dc thump? How long does it take before it goes away? both channels or one? The better the description - the better the guesses.
I had transistors on the input board of my 2105 start acting up. It would crackle after turn on for 20min to 2 hrs. I could not diagnose for a while because I would put it on the bench and it would not do it - then put it back in the system and it would happen again - very intermittent at first. Finally it started to happen more of the time and I moved it to the bench and tracked it down. So it could be a low level transistor slowly failing. This would probably happen in only one channel depending on where it is.
Intermittent problems are the worst!
Looks like you're less than 1.5 hours' drive away to Audio Classics. Maybe make it a day trip.
That must be nice. I'm in south Louisiana. There are no shops here like that. Closest would probable be in Texas for me. 4 hrs. or more.
