Cool!
For some months I have kicked around the options available for tackling the original 4100 Case.
It's been an on-off affair, and I once did order a case from AC, but then quickly canceled the order.
I had thought about exactly this as you have done as well, and felt it was a logical, simple and, in a way the most correct solution, just as McIntosh constructed their many other Cabinets-Cases.
I know my thoughts varied-wandered as fans here have thoughts-desires of a 4 sided Case. Sure, can be beautiful, but it also veers quite a bit from the bone stock 4100. I am of the camp to not necessarily alter-modify audio equipment like this, but I also say never say never.
I had thought about the processes, since I have/had some bit of experience working with Laminates, and over the years at Amtrak I probably "snorted" enough of the Green 3M Contact Cement to stock a Semi Trailer! Flooring, and other jobs at hand.
I feel the way you did it is the correct way, to remove the original laminate material, and not go over it.
Possible bonding issues, and it's exactly akin to putting a new roof over an old roof, it's a crap job.
I'd assume there's plenty 4100 examples out there that are in pretty rough-sad shape as far as the case is concerned, and in that event any dips-dings divots or dog bites on the case's MDF can be repaired prior to laminating.
My 4100 Case is fairly decent considering, but it is not perfect. A couple little minor scratches-dings on top near the rear cut-out.
A couple questions I have of you if I may? For our knowledge-enlightenment here.
Did you find difficulty in removing the original faux laminate? Was any excessive damage caused to the underlying MDF material?
Did you use one whole piece of Laminate to cover the Top Panel, or were you required to piece the material?
Are such Widths easily attainable without having to buy either massive sheets, or large quantities?
I ask this last question because I get a hankering that the reasons Audio Classics chose to "piece" the wood laminate on the top panel of their 4100 Cases, is because of availability, and cost.
Oh, did I forget to say Bravo!! Well done! Thank you for sharing!
