AA6U
I'm in the process of restoring a Mcintosh C11 and a previous owner did a very poor job rewiring/changing the power supply section. I am trying to bring it back to the original circuit (with new rectifiers and caps). However, because of their rewiring, I only have the schematics to go by. I compared the C11 and C22 power supply schematics and found they are nearly identical except that the C11 shows the negative terminals of first two 20uf caps (C101C and C101D) after the voltage doubler grounded, while the corresponding 20uf capacitors on the C22 (C30C C30D) are not grounded. Should I or should I not ground the negative terminals of those capacitors? See the schematics. Also, would the power supply benefit from additional capacitance? If so, how much and where?
