My C2200 preamp has four 12AX7 tubes in the line stage, and four 12AX7 tubes in the phono stage. The C220 has only two 12AX7 tubes in the line stage and two 12AX7 tubes in the phono stage, and the C2300 has the same tube configuration as the C220 plus two additional 12AX7 tubes for the moving coil phone stage.
Why does the C2200 use four 12AX7 tubes in the line and phono stages? Is one design superior than the other, or quieter?
NOTE: TUBE CONFIGURATION CORRECTED BELOW.
