Audioziast
Hi everyone,
I am owning a C26 which is non-stop producing hiss on both channels (independent on the position of the volume knob).
A technician is willing to help me out and get it solved... so went to his place where we hooked it up on measuring equipment.
Finally his advice was to replace the electrolytic caps as well as the transistors (as some got radio phonic) and having the pots cleaned (ultrasonic).
However, it was not entirely clear to him which transistors initially got used and which modern ones can be used to get them replaced.
Getting error when uploading pictures ...
So, I have been numbering the different transistors in a pic so one can easily refer to it. Please let me know if you want me to send the pic.
Also:
-Are the other parts still the original ones? (and again, best replace with...)
-The front panel is not evenly illuminated. There are three light bulbs inside that seem to work fine.
Any idea on how to get this corrected?
All serious input is very much appreciated!
Best Regards,
Also:
Best Regards,
